SignUp Now!I do plan to document and share the modification in great detail.Donnie,
This sounds very interesting, would love to see updates with pictures! (as I assume you will do as always)
You might check out a company called Autoweld Chassis (autoweldchassis.com/index2.ivnu). They will bend up any 2x3 to your specs (not generic frame rails like most offer).
Keep us updated!
Thx
What do you think of the Afco shocks. I've talked with some local racers that really don't have anything bad to say about them. On the contrary.Just a note about the QA1 shocks. The double adjustable is an OK shock for drag racing. Its taken a few years for them to come around. The valving is still somewhat odd but Todd @ TRZ thinks they are good shocks.
The Stange shock is prefered due to the quailty and performance. They can also be had cheaper if you shop around.
Love my Afco's. Compression is adjusted by turns on a knob and the extension by sweeps on the top of the shock. I found the rear shocks were more important than the front since I run so little travel. I have the dbl adjustable QA1's from TRZ for the front and like them......but they're no Afco.
On the notching. I'm a firm believer the bracing/roll cage tie in points are much more important than the frame itself. The last car I looked over had nothing but the rear part of the frame left....basically 1/8" thick or the factory thickness. This is to fit a 12 inch wheel and a 315/60 radial at a very low ride height. The roll cage was tied into the frame where the upper and lower arms attach to the frame as well as the where the spring pocket is. Special attention was paid to the section between the rails where the upper arms attach to the frame. There were several bars tying the main hoop to these mount points. From that point back, the frame only holds up the bumper. Rather than relying on the frame to support the bumper and parachute mounts. A "backbone" if you want to call it that, was ran from the main hoop, back to the bumper area to support the parachute mount.
Dusty. That setup sounds very interesting. I agree with you about the bracing/connecting to the roll cage. I've been studying the RaceTech Race Chassis School modules. Almost through the 4th of 5 modules. Even though the study course is geared for a full blown tube chassis, it gives great insight into how the different chassis loads are distributed through the whole cage. I'm trying to envision a cross between a simple roll cage and a well tied in rear section. It sounds like the car you're describing has some good ideas. I'm not trying to do a full blown funny car cage, just something very effective up to the 8.50 et limit, but I do whole heartedly agree that the rear cross member(s) should be tied into the main hoop.Dusty you didnt happen to take any pictures of the car did you?
