ok im just focusing on the block and i have done research and took my block to the most experienced machine shop i could find with the grand national.
Machine work:
cleaned
bored .20 over
aligned honed
decked
drilled 2nd and 3rd main oil holes to 3/8
will have balanced once i get parts
Part ideas:
(im trying to get as many parts as i can from cottons performance)
forged crank 4340 stock
COMP Cams® Roller Cam Kit
-(ductile roller cam, double roller timing chain set, adjustable roller cam button, roller lifters, and high performance valve springs & locs.)
K1 H beam performance rods (5.960)
Diamond pistons (.20 over) pro select rings (reccomanded by cottons perfromace for these pistons)
RJC girdle (20 bolt)
Billet steel main caps
i know this is just the block and i need several more parts to go along with this to actually make my car faster but im trying to sure up the bottom end so no matter what direction i decide to go in i know i will be able to trust the bottom. i would like some feed back on this to let me know if i did alright or if i should start from scratch again lol thanks for any help
Machine work:
cleaned
bored .20 over
aligned honed
decked
Part ideas:
