1KWIKSIX
- Sep 29, 2007
I have a set of GBody tubular upper control arms and need to fit some ball joints before I install these.
I've been reading that 1/2" taller ball joint on the top will get rid of some of the "Bump Steer" issues these cars have.
Two choices out there are:
Speedway Motor: AFCO Low Friction Upper Ball Joint 1/2" extended #20032-2LF @ $43.99 ea
or
Summit Racing : Proforged 1/2" Taller Ball Joint #101-10020 @ $49.99 (with free shipping)
Should I stick with the standard length ball joint or go with the extended upper?
Is there a preference AFCO vs Proforged? Is one better than the other?
If anyone has any experience with these or comments, would appreciate hearing from you.
thanks
dave
or
thanks
dave
