Restoration Parts Pile, Engine Harness, Rear Suspension, Frame Notch Kit, Hood Pad, T Top, 6266 Turbo
GNVYUS 1
TurboBuick.Com Supporter!
More parts gotta go after more GN restoration phases have finished.
1987 GN complete engine wiring harness just removed, has a new tps wire slice and I'm taking out my Red's Alternator Volt Booster. Boost solenoid wire is broke = $100
NEW In Box, NIB, T Top SS Center Cap, this piece goes on top, $140 new at G body. $100
NEW In Box, NIB, UMI rear frame notch kit, got from GNS at $130. = $100
NIB, New Trunk Trim, aluminum/chrome looking, lower piece on lid, got from G Body Parts, you'll need to spray black unless you like it, was $132. = $100
NIB, new hood pad insolation, Classic Industries at $230 then a bunch to ship. $150
Stock ECU, not modded = $100
Stock rear lower control arms, boxed with poly bushing, $100
Stock upper control arms, boxed with poly bushings, $100
Combo above for $200 shipped
PTE 62/66 turbo, JB, Ported Shroud 4" & 2.5",T3 .63 black coated, 5 bolt DP, fresh rebuild with new exhaust wheel. $750
(TURBO ABOVE IS NOT A BOLT ON FOR THE GN)
I will take the trunk lid trim. I will just spray paint it black.
