Retorque of ARPs with GM headgaskets?
scojack_2001
Livin' Like A Refugee
Just put the heads back on my motor. Used stock GM gaskets again and fresh ARPs rated to 200,000psi tensile strength. Torqued to 85 ft. pounds with a brand new torque wrench. They have sat for just about 24 hours as of right now. Will break them loose one at a time tonight and do a final torque.
Do I have to retorque them after a few hundred miles? There seems to be some debate on this subject. Not looking forward to doing this job again any time soon.
Thanks.
Scott
I would not break them loose, could disturb the thread sealant on the bolts causing a leak. You did use sealant right ?? I wouldnt think a stock style gasket would require a re torque, but if you are dead set on doing it I would get the engine up to operating temp a couple of times and then re torque without breaking them loose
Bryan
Bryan
Ok. I guess I'll just hit them again with the 85 ft. pounds and let it ride. Thanks Bryan.
Phoneguy is correct, if you're talking head BOLTS, then you do NOT want to retorque them, nor do you need to.
I can't get the link to pull up, but as long as you put the sealer on the threads only, and the lubricant on the head/washer only, you're good to go.
When we did my engine with ARP bolts and stock HG's, we retorqued four times before putting it back in the car and they moved up until the last retorque. We did it in the morning, once in the afternoon, once in the evening, and then one final the next AM before we put it back in the car. They've sealed great since!
It may not be required but the stock HGs are thick and take a bit to settle in. I wasn't comfortable until the bolts showed good torque without movement or at least minimal movement after being left to settle. And this method is at least easier than heat cycling and doing it in the car. I also agree to never back the bolts out.
Thread sealer on the bottom of the bolts, and lubricant under the head of the bolt and on both sides of the washer.
Thanks. Gonna hit it with the 85 one more time then it should be good to go. Still considering checking them after a few hundred miles and some boost (like 10psi or so).
Was instructed by a local TR owner/mechanic who i trust to break each bolt loose 1/2 turn and retorque. Not sure if I want to to that or not. We'll see.
Retorqueing studs is always a good idea, Bolts? no. You can check the torque, but not a good idea to back them out any for re torqueing.
I cant see any advantage to "breaking them loose". Re-torque yes, I torqued it down, let it sit over night, re-torqued, then ran it and re-torqued one more time. Victor Reinz gasket(I only did one side.)
What is his logic for "breaking them loose"?
With good thread sealer you can retorque it's not like rtv that will break lose and then leak.
Most of the time if you back the fastener an 1/8th to 1/4 turn then torque you will get more press out of them because you aren't fighting the break away torque it takes to get it turning...in other words even if it just clicks when you try to torque the fastener, if you back it off slightly you may still get more turn out of it.
Do 1 fastener at a time so the press stays on the gasket.
I guess taking the tension off of them. Not sure what I want to to. Gonna go with Collin here and back them off a bit then take them back to 85. Hopefully that will be good. The engine has been sitting for just about 40 hours now.
If you want to satisfy your curiosity mark the position of the bolt head before you crack them loose and retorque them.
I'd probably drop a GM seal tab in the radiator just in case you disturb the sealant.
Good Plan.
I guess I can see the "extra" the bolt needs to over come the "break away" but relaxing the seal is too much for me.
product_thumb2.php
x2 on the seal tabs. I used this on the threads.
I think Im just gonna hit them one more time at max torque and ship it. I need to get it back together again. Will drop some seal tabs in it as well.
Thanks guys.
I'm a big fan of the seal tabs, never had to use them on a TR but work great on small issues on my daily stuff.
Never click your bolts more than one time. You are over torquing them every time you do that. On aircraft, if I click a bolt twice the inspector will require me to remove and replace that fastener/tube. If you want to check torque, back off 1/2 turn and re-torque. and WHY would you torque a head bolt ot 85 ft. lbs??? It is a 7/16" bolt. Factory torque is 65 ft lbs. No gain and probably a bad idea to go that high, unless you have drilled and tapped the block for 1/2" bolts/studs. The ARP thread sealer down in the hole is still plyable afterr 24 hrs, and you are safe to back off and re-torque. That is what I do on head bolts. 4 steps up to 65, then 70 on the two longer bolts. Then let sit 10 minutes and then losen one at a time and a re-torque to full value. Then I am ready to run it. (to qualify the torque sequence, I have literally torqued many hundreds of thousands of bolts on airplanes, boats and cars over the 35 years)
Not a stock fastener, much stronger material require more torque to stretch. Can't use factory torque spec.
Thanks.
Scott
ARP bolts need to be torque at least 3 times to get the yield they recommend with ARP assemble lube and tread sealant. Also you will need to clean the black off the threads before installing for proper torque. Make sure the block threads are chased and clean. I wait 15-20 minutes in between the torque of the bolts. I back off one bolt at a time in sequence a 1/8 of a turn and torque again. No reason to fully relax the fastener.
Arp thread sealer doesn’t dry quickly, so you could torque the bolts again….
