Turbo V6 Camaro
- Jan 27, 2006
Any updates? Just wondering how the 3800 powered Grand National is holding up thru drag race season and if anything new has been learned about what works/doesn't work regarding the life expectancy of the factory parts under high boost.
I've got a stack of questions I was hoping you could answer.The mods are as follows.....
-Stock 98 L67 shortblock
-Ported 06 L26 NA heads
-60 lb/hr injectors
-Stattama Stg 2 turbo cam
-Stock 97 F-body 3800 intake manifold and throttle body
-LS1 MAF
-TE60 turbo, 4" inlet 2.5" outlet comp housing
-3" GN downpipe (Cody knows the brand), Modified for this engine arrangement
-Custom built forward swept log style headers. All 14ga stainless tubing 1 5/8" primaries going into 2" tube. Both side Y directly under the turbo flange
-Alky Control Alky injection
-Cartech style front mount intercooler
-Fully built 4L60E trans
-Vigilante 3K stall converter
-Hooker Catback exhaust
-98 F-body 3800 pcm
-Custom built wiring harness
-97 F-body dual electric fans
Did you remove the balance shaft?
Are you running a single-row or a double-row timing chain?
105 pound valve springs?
Does the LS1 MAF just bolt on to the v6 upper intake?
Did you have to build an AC delete pulley? What did you use?
Please PM me a price for a similarly built 4l60e transmission.
Thanks!
-No
-OE Style Timing chain and dampener
-Comp 105lb @ seat springs with .030" shims to raise pressure a hair
-The LS1 style MAF has a shoulder on both sides that require you to use a rubber/silicone coupler to attach it to the intake pipe and throttle body
-Things got creative here lol! I used the F-body style accessory arrangement with no AC compressor for the time being though AC may be added down the road, but it was already off of the car when Cody aquired it so it wasnt a big priority at the time. I took part of a 4.2 I6 Trailblazer idler pulley bracket, milled about half of it off and drilled and tapped a few holes to bolt it to a bracket that bolts to the engine. This allowed me to use a small grooved pulley and keep it away from the turbo yet keep things simple and routed properly
-I recieved your email, I will send you a reply with details.
Thanks!
Cool - thanks for the reply! I'm not looking to build an all-out racer and would be happy hitting the 11's in something I can drive comfortably every day so I'm grateful to you and Cody for sharing as much as you have.I replied above in BOLD
Whats the reason for not trying to use the L67 heads? I would think the injectors would be better in the head port for performance right? I understand it was easier to do it the way you did because you were using the L36 intake, but is there any way to use the L67 lower (maybe a custom sheet metal doghouse) OR the L36 intake and block the injector bungs in the intake and use the L67 heads and it's stock injector locations in the head ports? Why did GM do it? Was it due to lack of room in the SC intake for injectors or was it a performance thing?
I just got my hands on a 98 Rivi with the S2 SC3800 for a winter beater and it runs and looks great for 450.00 bucks. It needed intake gaskets and the previous owner could not afford the labor cost and wanted to wash her hands of it, so I ended up with alot of car for a small sum. I am driving it for now and it has 210k on it and still pulls like an ox and runs quiet and smooth as silk. I remembered this post and will def be using this L67 in my 86 GN eventually. The only thing I still don't know about is which heads/injector setup I want to use. The L67 in port setup sure looks better with the injector spraying directly at the valve like that,what do you think?
my car has AC here is my turbo kit :biggrin: :biggrin:
Garages > TurboV6Camaro's 1997 Chevrolet Camaro - FQuick.com << look at pics
