SignUp Now!Really? AWESOME! So Alky is definetely on the list now! Looks like im dropping 1,600 in the motor. Heres the list again! Lets hope its better this time
Alky Kit: $600
New Berrings: $50
Power Logger: $265
Fuel Pump Upgrade + Hotwire Kit: $175
Turbo Tweak Chip: $85 (I dont have a chip with my 87 ECM)
Adjustable Wastegate Actuator: $90
Adjustable Fuel Pressure: $110
Gasket Kit: $33 (w/o cylinder head gaskets)
Head Gaskets: $59
Valve Springs: $42
Big Mouth Air Kit: $225
ZDDPlus (6 Pack): $60
Total Cost: About: $1600-1700
Is that good?
I"m still learning here but I have to say I've received some very good advice from brad and boosted, my unqualified (compaired to them) opinion would be to take the money you save on parts bought off this board and add that wideband o2 and upgrade the tt chip to a 6.0 wide band to your list. Theres a lot things you can do (tuning wise) with a powerlogger and a wideband and the 6.0 chip.
OK, both of you Sr. guys are very informed, so I must have missed something.
You guys think he can do all this motor refreshing and parts upgrades for $2000?
I can run down a list and spend $10K pretty easy, but the advice I gave is based on the OP's $2000 budget.
Alky and clean stock injectors will be FAAAR better than ANY other size injector without alky, on a DD. (Ass-U-Ming pump gas), period. :wink:
Stock injectors and alky are enough to go low 12's for sure, and the COMBINATION of the sum of the other parts are not doing that.
Scenario 1
So, let say you look around, and sit and wait . . . . . .and locate a good TA33 for $400-$500 and install it.
Now, let me run down my mental listing with the TA33 in hand, all esle being equal;
-Stock injectors and alky will still be ok, correct?
-Scan tool will still work, correct?
-New chip is needed
-PS header is questionable with the larger turbo.
-Converter will most likely need to be upgraded.
-Stock DP is a killer with the larger turbo.
Scenario 2
So, let just say that the OP does NOT install the alky kit since the $$$ was spend on the TA33. (Still $2000 total budget)
You guys think the TA33 is worth the $$ at stock boost levels, with unported heads, stock PS header, stock DP, stock converter?
IMHO, the bottom line is this:
Those of us who have spend the $$$ at one time or another all know that "go fast parts" mean NOTHING without a good chip, a good scan tool and a good tune.
"Budget" and "Fast HA" do not belong in the same sentence, and stand by my second advice (After re-reading the original question . .
( you have to have atleast 60's for the TT WB chip to work)
Head Gaskets: $59
Quick Update: I have decided to upgrade using stages! I hate to keep bothering you guys, but I want to be sure! Take a look:
Stage 1:
Kirban Performance:
-Billet Aluminum ADJUSTABLE FUEL PRESSURE REGULATOR $105.00
-HEAVY-DUTY VALVE SPRINGS (12) SET $40.00
-ZDDPLUS SIX PACK 4-OUNCE BOTTLES (6) $59.70
Cotton's Performance:
-Heavy Duty Actuator $99.00
Turbo Tweak:
-Power Logger for Turbo Buick $264.99
-Fuel Pump Kit for Turbo Buick '340' Pump $119.99
-Fuel Pump Wiring Kit for Turbo Buick $44.99
-TurboTweak Classic Chip v5.6 (or upgrade) $85.00
Full Throttle Speed:
-Buick V6 Main Bearing Kit $29.99
-Buick Cam Bearing V6 $19.99
TA Performance:
Gasket Kit- Full set $130.00
V6 FELPRO STEEL HEAD GASKETS $125.00
Total: $1125
Stage 2:
ESP Performance:
TUR200 84-5 TA 33 TURBO W/O T-BODY $895.00
Turbo Tweak:
Wideband O2 Replacement Sensor for AEM $69.99
Injectors - 60lb, Set of 6 Flow Matched $319.99
TurboTweak Wideband Chip v6.0 (or upgrade) $89.99
Valve Covers w/ "Buick Motorsports" logo $139.99
TR Custom Parts:
Razor Alky Kit $599.99
Stainless Exhaust $650.00
Big Mouth Cold Air Intake $220.00
Total: ~3000
ment to type 50's. just changed out a set of 42.5 to 60's so i could use his new WB chip. with no other changes ( i had the old TT chip tuned great) we still picked up ET since it will clean the A/F up better over a longer area
2000 budget, lets save and get a 3,000 budget. hell lets just bust the budget![]()
Brent doesn't know what the word budget means.......for him it's all out or nothing. That guys been spending money on his car since his first pay check. LOL:biggrin:
Okay, I fixed alky, sensor, and as for the adjustable wastegate, I want to be able to put everything back to stock when I want a show car, or maybe just not go fast (as stupid as that may sound) that Is why I did not want to mod the intake for alky in the first place. And lastly, I am pulling the engine for a complete rebuild, why not throw some new bearings, and gaskets in?
