The first two are with my new rear spring setup and the others are with some old stock A-body springs.
I just fell in love with that car.. Now I want mine just like it lol.
SignUp Now!The first two are with my new rear spring setup and the others are with some old stock A-body springs.
if I'm not mistaken John aka "disco stu" notched the frame for that ride?
yes he did![]()
He turned my limping stock GN into a sleeper.. it's so much fun to drive now.
BTW I think your car is just plain gorgeous, really... it's near perfect.
If you dont mind, what are the specs for your wheels/tires/brakes/suspension?
If you have it all listed somwhere, I'd love the link as opposed to retyping.
Or, you can email a doc to glockandroll (at) austin.rr.com
Thanks for the compliments man. Here is the list of stuff..
Wheels:
American racing TT2s
front: 17x7" with 4" BS
rear 17x11 with 5.75" BS (I recommend 6-6.25" actually)
Tires:
235/45/17 nitto 555s
315/35/17 nitto 555R drag radials
brakes
front and rear LS1 Fbody brakes with EBC slotted and dimpled rotors.
Suspension
Front:
36mm 1Le sway bar, QA1 economy coilovers, Howe Taller lower ball joints, SPC adjustable upper control arms, ZQ8 bump stops and new steering components
rear:
A body lowering springs that drop 3" (RCS6034 1967-72 Rear Coil Springs 2" drop, pair)
UMI lower control arms
ATR rear bar,
frame notched
Bilsteins
Wheels:
Tires:
brakes
Suspension
Front:
rear:
ATR rear bar,
frame notched
Bilsteins[/QUOTE
I also live in Katy and my plan was to build mine excactly like yours except mine is a clone and will have a turbo 6.0 pretty soon after I get the body like I want it, I hope. If it isnt to much to ask i would love to see it in person.
Thanks Robert
Wheels:
Tires:
brakes
Suspension
Front:
rear:
ATR rear bar,
frame notched
Bilsteins[/QUOTE
Thanks Robert
Im running a 1/4" billet spacer back there right now making it 6" BS and yes when i pull into a parking lot at a steep angle and the rear twist a bit i get a slight squeal from inside rub.
OK, now I'm confused
You run 5.75" b.s. with a 1/4" spacer (=5.5" b.s.) but you recommend 6"+ due to rubbing on the inside ?? I think you would want 5.25-5.5 b.s.
Sitting in line, waiting for the gates to open at BG :biggrin:
yeah my bad, im sorry if i confused anybody, i had a brain fart, a lot on my mind lately. The wheels are 6.25" BS and i run a 1/4" spacer making them 6" So 6"-5.75 would be ideal if the notch is similar to mine. John thanks for pointing that out so it doesn't screw anybody over.
Thanks Robert
Welllllllll..... Ok... You talked me into it.Yeah now post some of yours! LOL. :biggrin:
Scot W.
My 86 T Type. GTA wheels, Cut IROC springs in the rear for now and cut Hotchkis springs in front. I didn't realize how much it dropped till I looked at some of these and some old photos:wink:
Wow that sounds like a cool project, send me a pm some weekend and Ill see if we can meet up
