Slammed Turbo Regal Picture Thread........
yes he did:cool:
He turned my limping stock GN into a sleeper.. it's so much fun to drive now.
BTW I think your car is just plain gorgeous, really... it's near perfect.
If you dont mind, what are the specs for your wheels/tires/brakes/suspension?
If you have it all listed somwhere, I'd love the link as opposed to retyping.
Or, you can email a doc to glockandroll (at) austin.rr.com
Thanks for the compliments man. Here is the list of stuff..
Wheels:
American racing TT2s
front: 17x7" with 4" BS
rear 17x11 with 5.75" BS (I recommend 6-6.25" actually)
Tires:
235/45/17 nitto 555s
315/35/17 nitto 555R drag radials
brakes
front and rear LS1 Fbody brakes with EBC slotted and dimpled rotors.
Suspension
Front:
36mm 1Le sway bar, QA1 economy coilovers, Howe Taller lower ball joints, SPC adjustable upper control arms, ZQ8 bump stops and new steering components
rear:
A body lowering springs that drop 3" (RCS6034 1967-72 Rear Coil Springs 2" drop, pair)
UMI lower control arms
ATR rear bar,
frame notched
Bilsteins
Wheels:
Tires:
brakes
Suspension
Front:
rear:
ATR rear bar,
frame notched
Bilsteins
Why would you recommend a touch more backspacing on the rears? Are you having some problems with rubbing?? I actually love how nice and tight you have the rears in there!
Wheels:
Tires:
brakes
Suspension
Front:
rear:
ATR rear bar,
frame notched
Bilsteins[/QUOTE
I also live in Katy and my plan was to build mine excactly like yours except mine is a clone and will have a turbo 6.0 pretty soon after I get the body like I want it, I hope. If it isnt to much to ask i would love to see it in person.
Thanks Robert
Wheels:
Tires:
brakes
Suspension
Front:
rear:
ATR rear bar,
frame notched
Bilsteins[/QUOTE
Thanks Robert
Im running a 1/4" billet spacer back there right now making it 6" BS and yes when i pull into a parking lot at a steep angle and the rear twist a bit i get a slight squeal from inside rub.
What would be the max I could go with those rims in the back without rubbing? What did you do to the front to lower it? I want to turn an all stock car into how yours looks without the huge rears lol.
OK, now I'm confused :confused:
You run 5.75" b.s. with a 1/4" spacer (=5.5" b.s.) but you recommend 6"+ due to rubbing on the inside ?? I think you would want 5.25-5.5 b.s.
Sitting in line, waiting for the gates to open at BG :biggrin:
yeah my bad, im sorry if i confused anybody, i had a brain fart, a lot on my mind lately. The wheels are 6.25" BS and i run a 1/4" spacer making them 6" So 6"-5.75 would be ideal if the notch is similar to mine. John thanks for pointing that out so it doesn't screw anybody over.
Thanks Robert
Wow that sounds like a cool project, send me a pm some weekend and Ill see if we can meet up
Here is mine. Stock (worn out) rear springs & 1 coil cut off of the front Moroso drag springs.
CC
My 86 T Type. GTA wheels, Cut IROC springs in the rear for now and cut Hotchkis springs in front. I didn't realize how much it dropped till I looked at some of these and some old photos:wink:
I like the red inner fenders and the GSX scheme! Looks great!:biggrin:
You guys are going to make me do some more trickery to my car for this coming season! Gotta keep up with the Jones'!!:p
HRE 18x9 Front 18x10 Rear
HRE 18x9 Front 18x10 Rear, drop spindles in front lowered springs in rear. Still debating if centers should be black?
Nice car!
Do you have rear spring isolators installed with the rear a-body 2" drop springs?
Do you ever take your ride up to the car meet at Home Depot off of Fry on Saturday nights?
