vacuum 6
- Jan 6, 2006
Breakin debris from a flat tappet cam. I 've gotten away with it on many rebuilds.
Yea the good old flat tappet...
SignUp Now!Breakin debris from a flat tappet cam. I 've gotten away with it on many rebuilds.
Also need some throttle body seals.
It does eat some oil.. And the soot, I dunno. Maybe from running rich? I really haven't driven on this motor a whole lot... What are you thinking?
Looks like a bad turbo seal to me. What up with all the black soot?
Where would one find these? GM parts counter?
I agree. Turbo seal looks wet. What are you grounding on the throttle body?
Not the best place for a ground. Also need some throttle body seals.
what kinda valve stem seals?
the ground is just for the fuel pump.... I only connect it when I need to run the pump with the car off (to get fuel from the fuel rail).
And for a turbo seal, I need to either get this one rebuilt, or trade up, correct? If so, any suggestions on a new turbo? I'd rather not change the setup in my sig, aside from the chip... so 60#ers and a 3500 stall... and no higher than about $1.5k..... Thanks!
---Ron
3500 is a lot of stall for a new style turbo. You can get a really big one! A 6262 only needs 28-3200 and that will touch 10's. If you like the set up get it rebuilt.
