vacuum 6
- Jan 6, 2006
If it runs like a bear don't worry about blow by.
2x
SignUp Now!If it runs like a bear don't worry about blow by.
-1If it runs like a bear don't worry about blow by.
If blowby is excessive, I would worry about excessive blowby.
If it's running good, I'd do a leak down and see what the numbers are. Then beat the crap out of it for a while and run the test again.
That's what I was planning on doing..![]()
how did you post video? I am having same issue did you take the motor out?This is a fresh build with under 2k miles on it. No reported knock maybe max was 25psi with Alky. I seem to have intermittent smoke out the catch can for breather. Haven't pulled plugs or anything yet. Car runs like a top. Oil is not milky and haven't lost coolant. It was smoking like this on jack stands. Also the car is not running a pcv if that makes a difference. Seems to be smoking on both valve covers..
Come on dude.
You gonna start this crap again?
