What block turbo and heads are you using to run those times???
RZ.
big ones
SignUp Now!What block turbo and heads are you using to run those times???
RZ.
big ones
Stage 2 with stage 2 heads. Wasn't intentionally trying to make a 9 second passion a pump gas tune but instead just trying to make a safe pass on a conservative tune. Like Bison said, I bet we could take a few degrees of timing out an even lower the boost and still be 9.x with pump gas.You're not supposed to kiss and tell when another man lets you look under his HOOD.
I bet he'll never be caught with his fly down around you again!!
Putting up $20000 then hoping someone will fork over the cash wouldn't be worthwhile. As far as "kits" you're still asking for a lot. John has $2000 to spend on valvetrain and Joe has $800. Why would John not take advantage of tue best of the best. The components vary by application and are too expensive to stock in most instances. I have enough to setup 2 sets of heads for aggressive lobes. That's it. Cams are ordered as needs and pushrod has to be determined after everything else is done.I wish someone would put together several complete different turn key proven packages or kits like cam , heads , turbo , converter, injectors , computer system and etc for your desired goal on your prepared block instead of this Johnny Cash method 1 piece at a time .
That's kind of a different tangent.... There's some guys hauling ass for relatively little.... and soe guys that are a vendors wet dream ripping off high 12s/low 13's with every .2/2MPH part they can buy.
I cant tell you how many times I told a customer on the phone to not buy any more parts but to just tune what he has before buying more stuff. Most of them call the next vendor and buy the part anyway in my experience. No one wants to tune, there is lots of cars with 10 second parts that go 12's, many times the vendor gets the blame for that when a guy is not happy with the outcome even though it is his own doing. I had a customer who wanted a 9 sec car, we put together a stroker combo and the car ran 9.70 with an extender chip. Exactly what he wanted. He called me and says "so and so told me m car would be way faster with an XFI, how much?" I explained to him that since he really did not know how to tune it and had no interest in learning it would be a mistake and the car would not really go much faster plus it had already met his goal. He called the other vendor and bought the XFI from him with a program "guaranteed to run better" 1st pass car went slower, 2nd pass he burned 2 pistons and 1 head. (for the record he did not buy it from Cal) he then asks me to "please help him fix it cheap" because he spent all his money on the XFI, when I told him what would need to be done somehow I became the bad guy. I could have just took his money, charged him to tune it and all that for him to get a very small increase in performance but was trying to help him. Just one example, I have lots.True, very true, that's what makes it so difficult for the novice to find what they need, not what everyone wants to sell them for minimal gains that could be avoided if people were more hands on with their cars instead of the mentality of what can I bolt on to get another second or 100HP.
Fish in a barrel, that's what some vendors see the clueless as,and rightfully so if TR owners don't want to do their homework then it can cost them some pain instead of pleasure.
The net is a double edged sword, opinions are like asses, everyone has one.
It's sometimes hard to sift through the BS and find the truth because nobody wants to be wrong.
there is another problem there too. Sometimes bad info or info that has changed lives on this board like a fungus that won't go away. There is a couple parts that had problems years ago, the problems were fixe years ago and no problems exist now. I still get calls and have customers that comment I heard that part has X problem, I usually tell them to check the date on the post here they just read because I know that is where they "heard" it. Sometimes they don't want to accept the truth or are skeptical which I completely understand but it does make things tough
But this is a bigger problem
As people read old and new posts and try to marry old tech that works in one situation and trying to find something that is the latest and greatest and will fix all previous problems or make them achieve their goals while refusing to grasp that you need everything working together to meet said goals.
And you / the motor/tranny are going to fail here and there along the way. If you cant except that you are in the wrong hobby/business.
Why are you directing that at me personally???
It wasn't..... You just read into it a little to deeply.... How about you ,me and all.
Combination has been the key and always will. My T top GN is old school, the most current part on it is a Direct Scan and my computer to monitor it has crapped out and I am thinking of upgrading to a Powerlogger set up if I can find an old laptop in a few weeks. Old 72 lb injectors cleaned once by Cody Motorsports, PTE chip, ESP front mount, SX fuel pump, Casper knock gauge, air bagged, non boxed stock suspension, TE 63 upgraded by Rick @ former Turbo Specialties to a TE66, funky ESP ( backwards cam), Turbo 350 trans and a 3500 stall Rev Max Torque converter( newest mechanical part) and 3.73 gears. Actually I stand corrected I did get a new Pypes exhaust system and replaced the Flow master set up. I purchased this car in 1997 beginning 98.
