GNBRETT
Pelennor Fields
- Feb 8, 2004
SignUp Now!I had the same concern so they installed a bar from one side of the frame to the other. The car is actually much more structually sound now then it was before. I don't have a good pic of it yet but you can see it here... I believe the price was around $1500. There is a wait tho. Worth the wait tho I think.Looks like fantastic work !
Dumb question though... Is there any concern about weakening the back half of the car with it notched that hard and no cage or rollbar ?
I though I remembered seeing pics of a GN with wrinkled 1/4's as a result of a hard frame notch and no rear support ?
That's pretty much exactly what I'd like to do to mine eventually... but I'd probably throw a cage or bar in the car too at the same time.
If ya don't mind me asking... Approx how much $$$ did a job like that cost you ? (PM me if you prefer)![]()
Build sheet so far is: 16k Astro roof Blue on Blue Turbo T blackout package. A/C and heat.
Motor
Don Cruz built girdled 109.
Bullet proof bottom end.
Champion GN1R. (Extensive porting)
Champion billet fuel rails.
Precision 96 lb. injectors.
RJC pulleys.
DLS external oiling system.
Mezeire electronic water pump.
Precision plenum.
70mm Accufab TB.
Custom valve springs.
Roller rockers.
TA valve covers.
Cam specs are kept secret by Don.
Turbo
6765 4 bolt DBB.
Remote Turbo oil filter.
RJC Maf pipe.
DP
JW Racing Custom 3.5 stainless.
Tial 44 mm WG.
Headers/Exh
TA stainless.
2 3/4 dual exhaust.
Front mount
PTE Slic.
Tial 50 mm BOV.
Razors Dual Alky.
Radiator
Alumitech aluminum rad. with dual Spal fans.
Brakes
Wilwood disc up front.
Hydroboost.
Alternator
March Performance Billet 140.
Driveshaft
Custom steel.
ECU/BC
FAST XFI with traction control.
Internal data logger.
AMS 1000.
Co2.
Transmission
Lonnie Diers 2004r Stage 2.
PTC 9.5.
Driveshaft loop.
Stage right TB.
Rear
Moser 30 spline.
Eaton Posi.
TA girdle.
Studs.
C-clip eliminators.
Suspension
H&R rear bar.
H&R adj. upper control arms.
H&R lower control arms.
Varishock double adj. front shocks.
Varishock single adj. rear shocks.
Springs coming....
H&R lower control arm brace welded in.
Frame braces up front.
Mini-tub.
Fuel
New fuel tank.
DP in tank.
Accufab FP reg.
Dual fuel system coming....
Wheels
American Racing Trakstars.
15x4. (no tire yet)
15x10 MT 325/50 DR.
More to come...
Yea, I struggled with it for a while since it is so mint. It still is mint, now it's fast and mint.I'm glad you decided to take a 16K mile car and work the balls off of it!!!!! :biggrin:. Keep up the good work
Looks great! I am sold on the plan to mini tub the Cutlass now. My bro is going to mini tub his GN this winter, maybe next winter he'll do mine. You know, let him practice on his car first.![]()
