Some Teaser Mini-Tub Pics.....
Shop cars....
Looks like fantastic work !
Dumb question though... Is there any concern about weakening the back half of the car with it notched that hard and no cage or rollbar ?
I though I remembered seeing pics of a GN with wrinkled 1/4's as a result of a hard frame notch and no rear support ?
That's pretty much exactly what I'd like to do to mine eventually... but I'd probably throw a cage or bar in the car too at the same time.
If ya don't mind me asking... Approx how much $$$ did a job like that cost you ? (PM me if you prefer):cool:
I had the same concern so they installed a bar from one side of the frame to the other. The car is actually much more structually sound now then it was before. I don't have a good pic of it yet but you can see it here... I believe the price was around $1500. There is a wait tho. Worth the wait tho I think.
Pics of my AMS with custom CAD designed holder made out of aircraft aluminum.
TA headers 4 Bolt.
Few more Mini-tub pics with rims.
GN Mini-Tub...
Looks Nice Brett...Nice fabrication work...Can't wait to see some pics with the car on the ground. Gonna be Sweet...
hello GNbrett; What's your plans for under the hood with meats like that it's got to be serious!
IBBY
Looking good brett!!
I was going to have a company do the same thing to mine so I can lower it as far as possible but I think the notch for the hinge may hit the tire when lowered with my size tires.. :frown:
Nice job though..
SW
Build sheet so far is: 16k Astro roof Blue on Blue Turbo T blackout package. A/C and heat.
Motor
Don Cruz built girdled 109.
Bullet proof bottom end.
Champion GN1R. (Extensive porting)
Champion billet fuel rails.
Precision 96 lb. injectors.
RJC pulleys.
DLS external oiling system.
Mezeire electronic water pump.
Precision plenum.
70mm Accufab TB.
Custom valve springs.
Roller rockers.
TA valve covers.
Cam specs are kept secret by Don.
Turbo
6765 4 bolt DBB.
Remote Turbo oil filter.
RJC Maf pipe.
DP
JW Racing Custom 3.5 stainless.
Tial 44 mm WG.
Headers/Exh
TA stainless.
2 3/4 dual exhaust.
Front mount
PTE Slic.
Tial 50 mm BOV.
Razors Dual Alky.
Radiator
Alumitech aluminum rad. with dual Spal fans.
Brakes
Wilwood disc up front.
Hydroboost.
Alternator
March Performance Billet 140.
Driveshaft
Custom steel.
ECU/BC
FAST XFI with traction control.
Internal data logger.
AMS 1000.
Co2.
Transmission
Lonnie Diers 2004r Stage 2.
PTC 9.5.
Driveshaft loop.
Stage right TB.
Rear
Moser 30 spline.
Eaton Posi.
TA girdle.
Studs.
C-clip eliminators.
Suspension
H&R rear bar.
H&R adj. upper control arms.
H&R lower control arms.
Varishock double adj. front shocks.
Varishock single adj. rear shocks.
Springs coming....
H&R lower control arm brace welded in.
Frame braces up front.
Mini-tub.
Fuel
New fuel tank.
DP in tank.
Accufab FP reg.
Dual fuel system coming....
Wheels
American Racing Trakstars.
15x4. (no tire yet)
15x10 MT 325/50 DR.
More to come...
Motor
RJC pulleys.
Precision plenum.
70mm Accufab TB.
Roller rockers.
TA valve covers.
Turbo
6765 4 bolt DBB.
RJC Maf pipe.
DP
Tial 44 mm WG.
Headers/Exh
TA stainless.
2 3/4 dual exhaust.
Front mount
PTE Slic.
Tial 50 mm BOV.
Razors Dual Alky.
Radiator
Brakes
Hydroboost.
Alternator
Driveshaft
Custom steel.
ECU/BC
AMS 1000.
Co2.
Transmission
PTC 9.5.
Driveshaft loop.
Stage right TB.
Rear
Moser 30 spline.
Eaton Posi.
TA girdle.
Studs.
C-clip eliminators.
Suspension
H&R rear bar.
Springs coming....
Mini-tub.
Fuel
New fuel tank.
DP in tank.
Accufab FP reg.
Wheels
15x4. (no tire yet)
15x10 MT 325/50 DR.
More to come...
Yeah that sounds like a real "street car" :rolleyes: :eek:. Looks good, just by the list of parts you have alot of money into it, not to mention the time it takes to install it all.
The car looks great and I'm glad you decided to take a 16K mile car and work the balls off of it!!!!! :biggrin::cool:. Keep up the good work
Yea, I struggled with it for a while since it is so mint. It still is mint, now it's fast and mint.:)
Its been on for awhile, and i am going to post just to get rid of the annoying message telling me I haven't posted in several weeks. Um can't think of a better place.....................................O Boy! That my friend is badass!
Looks great! I am sold on the plan to mini tub the Cutlass now. My bro is going to mini tub his GN this winter, maybe next winter he'll do mine. You know, let him practice on his car first.;)
Come on. The plasma cutter is fired up and ready to go. I got it all figured out. Your car first.;) Trust me.:D
Very nice job. I love the dark blue. Nice car. I am going to do a full notch with a 325/50 (maybe a 315/60 if I get a brake and looser converter) I like the clean tucked look. This thread is going into my favorites for sure. This is what I like to see. If you are going to cut them up, do it in a clean way with a purpose. You are motivating me.
