Stock coil to distributor conversion checklist
ok, dist is in. I realized I cant use my IAC angle boss anymore. it is so close to the dist cap that i would never be able to put the plug on and thw wire would be running voer the plug wires. I have a 4in turbo inlet pipe, I dont think this thing is going to fit either. :(
It all fits, it just needs a little reworking. Use the new style IAC and adapter sold by injection-connection. You may have to cut/weld your 4" pipe to work, its not easy to put a distributor in as you see, I made bracket up so the inlet pipe doesnt tear the cap off when you launch the car also. Heres the link to the thread from last year. Here is a pic of the inlet pipe, i had to patch some holes from some evac fittings, so don;t look at the crummy 3 patches.:eek:
http://www.turbobuick.com/forums/stage-ii-tech/182033-correct-way-set-up-distributor.html?highlight=distributor+install
