STOCK turbo racing class, Any Interest??
Ditch the true radial rule. The last thing an event needs is a class of cars tearing the track up for the rest of the classes. All classes should require drag radials like BFG, M/T as a minimum.
Like was already said. This class will be extremely boring racing on true radials and a full tree. Let them have good tires so they can leave on some boost. The Pro-tree is much more fun once you try it. You see yellow and you go.
Great feedback folks. I will adjust the rules and post them for review. Thanks again.
Jim C. - GSCA Race Director
How about this set?
Factory Stock Appearing – FSA
General
Most parts of the car will fall into one of four categories:
1) “Correct” OEM parts. These parts must be proper and they must be Original Equipment Manufactured (OEM) parts, no aftermarket external markings of any type. Examples: Intake manifold and cylinder heads.
2) “Correct” parts. These parts are the same as “Correct” OEM parts, except they do not need to be OEM manufactured. Reproduction parts, that duplicate the Correct* Original parts in appearance, form, function and material and are primarily designed as “restoration” parts are allowed, as long as they comply with all other applicable rules. Examples: wheels, upholstery, emblems, replacement sheet metal, etc.
3) “Spec” parts. Parts that meet a specification defined in the rules, but are not necessarily “Correct” or stock appearing. Examples: tires, exhaust system. Note: Every effort should be made to achieve a stock “look” with these parts. For example; your car did not come from the factory with a 2-1/2” mandrel bent exhaust system. But it is specified in the rules that you may run one. Do not have it powder coated pink or highly polished stainless. Rather, try to keep the finish somewhat consistent with what the original correct* exhaust system would have been.
4) Correct Appearing. Everything not specified otherwise must be correct appearing. “Correct appearing” and “appearing correct” means: upon a cursory visual inspection by someone reasonably familiar with the year, make and model claimed, it looks like a “correct” part.
Heads-up 4-tenths pro tree start and pro ladder. (1 vs 16, 2 vs 15, 3 vs 14, 4 vs 13, 5 vs 12, etc....)
All cars racing in the Turbo Heads-Up racing classes must be owned and driven by a current member of the GSCA.
No peer technical inspections relating to safety equipment rules by class participants or peers, Beech Bend Raceway track safety technician personnel will make all rulings on track safety related items.
Winner and runner-up are subject to re-weigh and re-tech immediately after final round or at any other time.
Any entrant caught trying to deliberately break the rules will be disqualified from the FSA class.
To compete in this class the car must be Factory Stock Appearing with the following exceptions and/or clarifications:
Definition of "Factory Stock Appearing"
A factory stock appearing part is a GM part originally delivered on a 1986 to 1987 Buick Regal, GNX, Grand National, T-Type or Turbo Regal from Buick Motor Division and is externally stock in appearance. No external welding, cold weld epoxy, puttying, etc. may be done on any factory stock appearing part unless specifically stated. See Engine section for cylinder block requirements. * Note: GM exhaust headers may be welded on externally to repair defects. This includes the driver's side header area that is prone to cracking and may include welding on both driver and passenger side header between the primary port and mounting flange. Welded in EGT gauge probe bungs are allowed. See Engine and Engine Management section for cylinder block and ignition requirements.
Chassis
Seat belts, lights, horn, and windshield wipers must be operational.
All factory headlights must be in place during competition.
Helmet required. Cars must pass track safety inspection.
Car should possess all applicable safety equipment for potential ET/speeds attained.
Minimum car weight w/driver must be at least 3,500 pounds.
Complete stock, painted TR/GN body required.
No fiberglass or carbon fiber body parts, bumpers or hood scoops.
Stock operating glass windows and windshield required, no lexan.
Engine/firewall must be in stock location.
Stock wheelbase required (108.0" measured).
Factory stock appearing inner front wheel wells required.
Factory stock appearing front suspension components and mounting locations required w/any type stock location shocks. Swaybars may be removed.
Factory stock rear suspension locations required with any type stock location shocks.
**All control arms must use the factory mounting location. No bolt-in or welded relocators allowed. (ie. Southside bars).**
No quarter panel modifications except rolled inner fender lip.
Minor modifications to stock rear wheel wells (no mini-tubs).
Outer frame rail notching is allowed. Inner frame rails remain stock. No inner frame rail reinforcement allowed.
No ladder bars or coil over equipped rear suspension.
No wheelie bars or parachutes.
Brake system must be either Power Master or vacuum boost operated, no manual brakes allowed.
Brake system line locks allowed.
Drive shaft safety loop required.
Driver's name and club decal on side/quarter windows allowed. Sponsor/vendor decal is acceptable on the rear window.
A maximum of 2 hood mounted gauges are allowed.
Engine
Buick V6 block < 236CID max.
**Block casting number 25526109 only. No Stage or A/M blocks!!**
Must use DIS type I or II ignition, NO distributor.
8-bolt Iron cylinder head castings required. No Stage 2 or aluminum heads.
Factory valve covers and oil pan required.
No dry sump-oiling system.
Factory stock intake manifold required. No external welding allowed * No modifications such as welding, cold weld epoxy, putty, etc. may be done on any portion of the intake manifold runners to increase manifold air flow are allowed.
Factory stock appearing cast aluminum intake plenum allowed.
Factory stock appearing throttle body required. * Throttle body may not be bored. It may be bellmouthed so long as it retains the factory stock appearance.
Factory stock appearing driver's side exhaust headers. No ATR, Hooker, Terry Houston or Poston replacements allowed.
Factory crossover pipe required. No delta gates allowed.
Any single or dual exhaust system allowed. Must muffle and exit in stock location(s) (3.0" max size). * Exhaust must run through mufflers in competition.
Factory downpipe and elbow from the turbo is required. It must be routed down through the stock location. No flex pipe allowed.
Turbo
**One (1) factory stock, Garrett 3-bolt turbo required as came on the vehicle. No ball bearing turbos of any type.
Intercooler
Factory stock location air to air intercooler required, Duttweiler style modifications allowed but must be painted to match and no visually obtrusive.
No front mount intercoolers are allowed.
No liquid intercoolers, intercooler external spray cooling, or add-on cold boxes allowed.
Engine Management & Fuel System
Stock ECM or modified stock ECM only. NO aftermarket fuel system systems allowed, (DFI, FAST, Motec, etc). NO speed density systems.
Factory Stock Appearing (Type I) or (Type II) DIS cam position sensor required.
No individual coil per spark plug ignitions allowed.
No distributor ignitions allowed.
No delay boxes, throttle stops, or crossover boxes allowed.
Any intake air induction system allowed.
Factory MAF or LS1 with translator sensor is required. All intake air must pass through and be measured by the MAF sensor.
Any fuel pump(s) allowed. * Note: Fuel pump(s) must not be visible from outside of car.
Voltage increasing and fuel pump hot wiring devices are allowed.
All factory stock appearing fuel lines required.
Factory stock appearing fuel rail required.
Any type fuel pressure regulator allowed.
Any high-impedance fuel injector allowed, 6 maximum.
Factory stock appearing fuel tank required with no additional cells or sumps.
Gasoline fuel only, no fuel additives or nitrous oxide injection allowed.
Alcohol injection is allowed.
Engine Compartment
All accessories must be present, in stock location and in working order.
Air conditioning operational w/belt in stock location.
Power steering operational w/belt in stock location.
Stock alternator operational w/belt in stock location.
Stock water pump operational w/belt in stock location.
No engine compartment dress up is allowed with the exception of chromed or polished factory parts.
Battery, one (1) only and it must be the stock location.
Stock type electric engine cooling fan required.
Any stock or replacement radiator in stock location allowed.
No short belt tricks of any type.
Transmission
GM 200-4R transmission required.
Any size torque converter acceptable, with or without lock-up.
Any transmission oil cooler and pan allowed.
Stage-Right style transmission brake allowed (No electronic style.)
Differential
Factory stock appearing differential housing required.
No differential spools.
Any gear ratio w/factory stock or reinforced differential cover allowed.
Tires & Wheels
Any slick up to 28x10.0 is allowed. Any drag radial that can fit without frame nothing or mini tubs. Tires may not be shaved to meet dimensions.
Front tire footprint must be at least 5.0" wide.
Must use a factory rim.
How about this set?
General
Chassis
Engine
3-in downpipe is allowed. It must be routed down through the stock location.
Turbo
Intercooler
Engine Compartment
Transmission
Differential
Tires & Wheels
Jim,
Explain the reasons for the following:
1.) Why allow frame rail notching? That shouldn't even be a thought on this class.
2.) Why allow a 3" DP when running the stock turbo? IMHO, if the class is for stock appearance and you go through the lengths of making the stock turbo a rule so should the DP.
3.) Stock MAF or translator MAF only. Kinda caters to a particular vendors product... Any MAF, all air must pass through & be measured by the sensor. Those are actually my words that were added (2) years ago to the other H-U classes.
4.) Again... Why high impedence injectors only?? That makes absolutely no sense, as mentioned in an above post.
5.) Trans-brake?... What!!
K.
I can tell you one thing. I see no reason for running a pro tree in such a class. Many of the folks that would like to run their "stock" cars probably don't have a wealth of experience at the track and will immediately be discouraged by those that do have such experience killing them on the tree.
Why a pro tree? why not a standard bracket tree? The pro tree suggested by those that can "nail" it?
The Pro Tree Kicks ass for Turbo Buicks, since no trans brake nonsense will be involved with the class. No "experience" is required and it takes about 3 times to figure it out. When the yellow lights flash, floor it and release the brakes.
It's also better for the fans who watch the races as they will go to the finish and not be over at the tree by redlight.
The Buick vs. Mustang shootout in Oklahoma went to Pro tree and almost every race is worth watching vs. Pre Pro tree, when it was 25+ Buick losses to Redlights from pushing through the lights. The only people bitching are the ones with monster turbos that take time to spool. This shouldn't be a problem with a "stock" class.
Sorry, after a little over 40 years of bracket racing off a standard tree, I guess a pro tree didn't sound appetizing.
how about letting in TTAs? :biggrin:
NO :biggrin:
Unless the TTAs are required to meet a 3700 lb requirement.
As known the TTAs are 2 tenths and 2 mph faster do to areodynamics, so lets make it fair :)
The first set of rules are looking great, keeping the car stock appearing as possible.
One question. Stock electric fan only, or can we run the dual fans that most venders are selling?
BW
I agree. If any one of the above is ruled to be stock, they all should.
K.
Its a stock turbo class, i would like to see more people running low 12s consistantly with a 3 inch downpipe and a few mods to make it interesting.
If this class does turn up for next year, why not make it interesting and see how fast some cars can go with some decent modifications done to the car and limit it to the stock turbo?
I do see alky kits are on the lists, man that helps everyone out :biggrin:
BW
NO :biggrin:
I'll run a TTA meeting the rules at 3700 lbs :) Wont have to add much weight either, last time I weighed one of my stockers it was 3610 with me in it :eek:
As for being faster due to aerodynamics, I dont belive at the speeds a stock turbo can reach that aerodynamics plays THAT big a part.
The rules look good, but I wouldn't get too picky about things like stock crossover pipes. Almost every car I've owned the crossover was hammered dog crap and had to be replaced. I didn't replace it with a "stock" one, but my car didn't get any faster, either.
Stock equivalent or stock replacement should be good enough.
It's silly you could run a THDP but have to run the factory crossover.
If you make the stuff that actually effects performance mandatory like Turbo elbow or stock neck intercooler, the other stuff you can be less picky about.
Well noted and good point. I will adjust the rules accordingly and post them. There have been several changes made.
Here is what we have thus far -
General
Chassis
Minimum GN and Turbo – T w/driver must be at least 3,500 pounds.
Turbo T/A must be at least 3,650 pounds w/driver.
Outer frame rail notching is not allowed.
Engine
Factory stock appearing throttle body required. * Throttle body may not be bored. It may be bell-mouthed so long as it retains the factory stock appearance.
Factory crossover or replacement pipe required. No larger than factory. No delta gates allowed.
Turbo
Intercooler
Factory stock location air to air intercooler required, Duttweiler style modification allowed but must be painted to match and no visually obtrusive.
No stretch stock location intercoolers.
Factory MAF or LT1/LS1 with translator sensor is required. All intake air must pass through and be measured by the MAF sensor.
Any fuel injector allowed 6 maximum.
Engine Compartment
Transmission
Transmission brakes are not allowed.
Differential
Tires & Wheels
Any slick up to 28x10.0 is allowed. Any drag radial that can fit without frame notching or mini tubs. Tires may not be shaved to meet dimensions.
I like all of the rules except two-
3-in downpipe is allowed. -This doesn't fit any of the 4 categories and really takes away from the stock look.
Must use a factory rim. -Factory rims are hideous!!:D
How about running a 8" slick instead of the 10" slick??
Any MAF??
Does the stock turbo have to have the Garrett .63 exhaust housing on it??
K.
