SignUp Now!yes, it integrates directly into TunerStudio, everything gets logged in one logfile.Does the Microtcu work with ECUGN?
I'm looking for the notes of where that info came from.
The Energy one is the one I have. That rubber one looks like its the same size, I think I'll pick one of them up also. Should be test fitting soon. (Stay tuned for pics)
Like a dog with a boneWe run co2 on the air shifters for glides and 400s.
You can pick your shift points.
You can also run a Reid ultra bell which will give more clearance to the body. It also makes install and removal a little easier with the added clearance. This is the setup I use and have zero mods to the body.most people will want to use a controller, then it is programmed for shift points, shift pressure, lockup, etc.
generally, you want to use the controller that matches your ecu, so they communicate data and the logging is coordinated.
for the stock ECM, there are various controllers that work in "standalone mode".
For the 'real racers', there are manual valvebodies and such.
Installation is not complex, but there are a couple changes needed. (adapter plate, crossmember, driveshaft, shift linkage) I am working to collect all the specific details all in one spot.
Bob
I’m following along closely Bob. About to pull the trigger on a 4L80e from a local race trans builder… he’s got 4L80s running 5.0s@138+ in full auto mode and still using lock up.Like a dog with a bone
I believe the Reid bellhousing (and their full bad-ass 4L80E case) is dual bolt pattern, so no adapter plate would be needed to bolt up to the Buick V6.You can also run a Reid ultra bell which will give more clearance to the body. It also makes install and removal a little easier with the added clearance. This is the setup I use and have zero mods to the body.
My 200 is pulled, my 4L80E is fully assembled. so just need to get it bolted in, measure for the driveshaft, and hook everything upI’m following along closely Bob. About to pull the trigger on a 4L80e from a local race trans builder… he’s got 4L80s running 5.0s@138+ in full auto mode and still using lock up.
I know we’ve messaged about the details of the swap before, so I’ll be diving into this soon.
I just installed another fresh Janis stg 3 so that should hold me until next year but…I’m about to start buying all the 80e stuff now.
I’m so over these freakin 200s. I’m $7-8k deep in a pair of full billet 200s and literally had them both broke at the same time….second one is shipping to Janis for a full rebuild this week, then it will be on the chopping block.
People comparing 400 swaps to 4l80 swaps for street cars that get driven a lot just don’t know what they are missing.
And yes I have one of my cars with a 400, it’s been driven cross country twice, I know they “can” do it….but it’s SOOO much nicer with OD and lock up. Not to mention the shift point and firmness tune ability with the ECU is so much better…
The pump is leaking on my 200. I was talking with Prasad and may install a 4l80 I have sitting. I bought it From Chris at Ck back in 15 or 16. Car has ecuGn in it. So who do I get controller from? May go with jw bell housing. Engine is out so may be the time to do it.My 200 is pulled, my 4L80E is fully assembled. so just need to get it bolted in, measure for the driveshaft, and hook everything up
(cooler lines, linkage and cable, speedo cable, controller)
I pulled all the stock shiftpoints out of old PowerLogger and ecuGN logs, so I have the tune built and ready.
Bob
