Turbo Keith
TURBO KEITH
- Sep 16, 2015
True BUICKTIME , Its been alot of good reading , I have talked with Bison and may make an upgrade with the turbo in the future , She pulls like a freight train now LOL
Wish I saw this post sooner. I had a TA49 after my stock turbo and it spooled well. A friend had a 6262 bb and we swapped it out and tried it, it took some peddle to spool; great on the highway, but a bitch to build boost on short road. Put the TA49 back on, then somthing passed thru my intake pipe and tore up the blades. Needed a quick replacement and bought a used precision 5858. That thing was a beast on stock setup, i would light the tires up every chance I had. Added, alky, fmic, tr6, bigger injectors, PTC converter and then went to a 6262 ball bearing. Initially I was somewhat dissappointed, but blew a head gasket and decided to upgrade heads, thanks Bison.Ok , Let me clear up about going to the track . I had said in this post I haven't been to the track , But I have and the reason I said I hadn't is because this past summer I went to a local track 1/8 th mile and made a couple of passes . The best being 7.63 @ 24 lbs of Boost . I did not have a Line Lock installed , I'm doing that now , So I couldn't build any boost leaving , spinning the tires . Now please understand I AM a ROOKIE and was nervous as HELL . Yea I could have stayed and made more passes but I was not gonna beat on my car and plus it was hot as hell . I'm not gonna go to the track that much but I would like to say I have a ______ ( time slip ) fast car . So all that being said was to get back to the question ta49 vs 6262 . I was hooping a member has very close to my set up and may have had a 49 , A good 1st level upgrade turbo , and then went to a 6262 or something else and could give me some feed back if they could tell any gains or if its not worth the time or money . I have read all the post here and I do thank yall for the help and knowledge . TurboKeith
You don't see the 5858 being run very muchIt seems the 5858 (620 hp rated) would be a bit of an upgrade over the TA49.
Too bad there isn't something like a 6060, if that would be more in the middle?
Maybe no one would use one and that's why there isn't one?
Just thinking out loud.
Nothing hits like the t31 with the Garrett .63 especially when the converter is marginal.
Would this be the TA49, TE44 or the TA58?
He talking about T31 exhaust wheel. Comes on the older ta49/44/6131....that's fine with .63
You have to find the balance between spool up and top end. With that being said , I would put a Pte or .82 on everything above 61mm.
60-1 or smaller a .63 is fine. But even small 60-1 (59mm) wheel with choke off in a .63 if you where pushing at it's max flow.
Fortunately opinions matter zero when data proves otherwise
Hi Bison, not understanding your response.
I wouldn’t expect you to understand. If you did you wouldn’t have posted
Sent from my iPhone using
Tapatalk
