SignUp Now!I would say with that combo you better see between 575 and 600 HP and close to 700Ft lbs.
I am just so pleased with the way it runs like a stock, quiet GN with ice cold air![]()
Do you think I should back off the timing or is the theory to run as much as possible at a given boost as long as KR is not evident? I have seen many setups running about 22 degrees(3rd 4th) with the higher boost and some even scratched into the nines.
NO Dyno yet. Our closest track is 1/8th mile my best ET was a high 6.9 (call it seven flat) I had serious traction issues and left about 3/10's on the table from my previous best 60 ft.
I am installing the HR bar and upper/lowers and going back for another try. The best time I saw the slicked 06 run was a 7.8![]()
Julio, your kit is working well I am at 28-30 PSI (ball bearing 67) on #4 with the dual nozzle, with about 24 degrees across the board for timing. So far.. 1st and second yeilds about 2 degrees of KR . I have to back off as I am simply going too damn fast to slowly see what 3rd and 4th yeilds. Guess it will be @ Bradenton or a late night interstate run to see if your kit and Eric's chip can stave off knock @ those boost/timing levels![]()
This is a good point. I may have guessed a little off on my numbers. Torque and hp may be closer to each other than i thought with that cam. Fwiw my buddy went 127+ with a similar setup and a 210-205. Car weighed 3700 lbs with driver. Unfortunately we never dynoed it. I shifted it at 5700 and it went to a little over 6100 crossing the line with 28.5 in slicks.Sorry. How high are you reving that motor with that camshaft? Just curious where that cam runs out of steam (or float starts to give you problems)
