SignUp Now!The car spools way to slow compared to a stock Turbo Regal.I guess the L/U 10 inch 2800 converter is the one to go with.
have you done anything with the tune to help spool it??
I've talked with you before, hit me up if you would be interested in my PTC. I am going to go to a 9.5 n/l this year.
Yeah I have set mu 02 volts and made sure it was not running to rich.It does not spool anything near like a stock Turbo regal would.What is your PTC converter,stall speed and LU or Non LU??
are you sure you have no exhaust leaks and the wastegate puck is sealing? i know when we ran a TE44 on a stock D5 converter it spooled almost as fast as a stock turbo
No leaks.I do have a Racegate set up which might be the reason for the slow spooling but I get different answers that having a Racegate slows down the spooling of a Turbo.
I'm running one of our 2800 Non Lock-up converters and it works perfectly!
I would do some checking on your racegate to make sure it's not that first before going with a new converter.
If you choose to go with a new converter keep us in mind, Compare our warranty and Standard options with others!
Click here to view our converters> GNS
Scot W.
There is no noticable difference between the Non Lock-up and Lock-up other than when it locks up, other wise they are the same. The Non lock-up is perfectly fine on the street and very street freindly, the Only thing with the Non lock-up is only a few hundred more RPM's on the interstate..The Racegate was checked many years ago and it is fine.It just botheres me that 1st gear my car takes a bit to get into Boost.I thought Non Lock-up converter's are not very street friendly.I don't race the car but I want the car tuned and ready to fly if I need to pass someone quick on the highway.Maybe my ESP big front mount intercooler is causing the slow spool?? Another thing is I don't like my 009 injector's.Someday I will get the 60lb injectors.
Either a restalled D5 or 10" LU PTC would be nice.
Why are you shifting it manually, is it not shifting high enough? If so, have the governor tweaked.
BTW: The larger intercooler should actually make it spool better/quicker..
Most guy's seem to like the PTC 2800-3000 10 Inch L/U converter for the TE-44 Turbo.Anybody like a non/lock up converter on the street with the TE-44 Turbo??
