jasjamz
THS Racer
- Sep 30, 2004
What rpm do you shift at?
Is that a roller or flat tappet cam? Its on the large side for your goal. This will require higher shift points, better flowing heads, or more cubes. I know it sucks to heard your combo is all wrong. I've been there too. It really is confusing at times to see a car with much smaller parts go faster than you repeatedly.
Does that converter really read 3000rpm at 0-1 psi?
Comparing a PTC 9.5" to regular converters really isn't a good comparison. They stall low but ramp in faster than others that are "rated" at the same stall speed. I too like them looser on the bottom end to get the car off the line. I make due with top end slippage as long as its not really bad and it drops respectively on the shifts.
