Toby_Goodmk
Test Fit officianto
 - Dec 9, 2011
Heard thatplease test carefully.
B
SignUp Now!Heard thatplease test carefully.
B
I maybe reconsidering my Racetronix 510 double pumper. Second pump doesn't kick on until 15# and that maybe too late. I do have a larger return line, so maybe have both pumps on at all times? Just thinking out loud
Cal would be happier if the fuel pressure is correctedyea, I need to increase it a bit. I am not sure to mess with it too much as cal has this thing dialed in pretty well.
I disagree, I would ask Cal as injectors are spec'd at 45# fuel pressure.Don't mess with it if cal tuned it to what it is currently. Now if you see him again let him know you want to up the base pressure and he can dial it in again.
Sent from my SM-N930T using Tapatalk
I had commented to Cal that I forgot my allen key to adjust base fuel pressure up if needed, he commented he didnt need to as he would tune accordingly. It is set at 43 line off.Don't mess with it if cal tuned it to what it is currently. Now if you see him again let him know you want to up the base pressure and he can dial it in again.
Also, what are you using to get your volts so high?
Ok, then you are good to go!I had commented to Cal that I forgot my allen key to adjust base fuel pressure up if needed, he commented he didnt need to as he would tune accordingly. It is set at 43 line off.
I just installed one. I was getting 12.8v, and shot up to 14.3. I am thinking it should be higher, but not sure where else to look.I use the caspers volt booster, It works very very well.
Why would it matter what the base fuel pressure is if the car runs properly, isn't near out of injector, and fuel pressure is 1:1 with boost?I disagree, I would ask Cal as injectors are spec'd at 45# fuel pressure.
BWhy would it matter what the base fuel pressure is if the car runs properly, isn't near out of injector, and fuel pressure is 1:1 with boost?
Because that is what fuel injectors are designed to run at. But why would you want to run them out of their designed range?
Opinions are like assholes everyone has one. Is it true or false that the recommended injector range is between 41-47#. Not your opinion but what the manufacturer recommends. I received this information directly from Bosch and racetronix. You should stop face palming as you are going to give yourself a concussion.Double face palm
You should have 13.6 v, you may not be exciting the alternator.Ok, then you are good to go!
