V
v8440
Guest
Hi all,
I've searched the transmission topics for this info and not found it, so here goes: I have a car with a short shaft th350, and I have a pretty well built 2004r that I want to replace it with. What must I do to accomplish this? Specifically, do I have to shorten or lengthen the driveshaft, where is the transmission mount point compared to the th350, and is the spline count the same on the 2 output shafts? If it matters, I have an aftermarket B&M ratchet shifter in this car, so I'd imagine the shifter won't be a problem.
