- May 27, 2001
Jay you are 100% correct when saying " Buy what you need, not what everyone else has." h
Here is my theory on the 60# injectors. Wether or not you NEED them or wether or not you want them. When steping up to a larger injectors like the 50# injectors My point is that you can get the 60# injectors at the same price as the 50's so why not go ahead and get the larger 60# injectors? It won't hurt your combo, It won't hurt your drivability, They will lower your duty cycles, they will allow you to go larger on your combo in the future if you want and you won't NEED injectors then. So I see buying 60# injectors a Win / Win situation and pretty much a "One time buy" for most street cars..
New, Going from the 42.5lb to the 55lb injectors is only a $10 differance. Going from the 55lb to the 60lb injectors is only a $8.99 differance.
Scot W.
If that were the case then why does Detroit put different size injectors into every car? They could just put one injector into every car and calibrate around it.
Im all for getting the most bang for the buck but trying to cut those large injectors back to make them idle on a vehicle that doesnt need them can be a challenge. Also, fueling at WOT can also be a challenge since your basically making a leap of faith once the MAF maxes out. Granted some of the newer chips give you adjustability there but depending on what the initial curve is like, sometimes even thats not enough.
Buying what you need to reach your goals makes everyone's life easier. I just dont see the point in buying bigger just because its in the same price range, especially if youre never going to use it.
By your logic, there are about 15 different turbos that are the same price so you might as well buy the biggest one iin case you need it.
