TURBOPOWERED68
David
- Jan 31, 2006
have a question for ya.. how fast did you go with this car ??? is the "17s" the best the car did?? I wouldn't blow threw more $$$ till the car goes 12s anyway like it is. is the $$$$ burnin a hole in your pocket ?? if so get the new parts then and try and find your problem after you get it all back together an still run the same times.
I completely understand your point and agree with you but check this out for me please.
http://www.turbobuick.com/forums/ti...day-i-wanted-burn-my-car-after-first-run.html.
First Run @ 17.99"the car pulled hard out of the hole then just went completely blank at about 30 or 40 feet from the starting line, so I lifted then got back on it and finished the run"
Second run "15.255 with no Sputtering "
Third run @ 17.19 "So I line up at the tree build 5 PSI of boost then let it rip and the car dies again so I let of then got back into it. This was the out come of the last run.
Since these runs I have replaced the module and coil plus I went over every wire and sensor in the car and it hasn’t sputtered a single time.
But then I run into this.
http://www.turbobuick.com/forums/turbos-turbo-related-parts/271140-i-need-new-turbo.html
So now that I wasted all this time with used parts that fail just when the car starts to show some life. I am now going to give it a shot with new parts that hopefully won't fail right when the car starts to get close to coming alive.
I have read that the Valve springs should be replaced to help with the top end and to avoid valve float or what ever it’s called. So why not?
My turbo is NO GOOD So I need a replacement. I am not Buying another rebuild or used unit.
With a new and bigger Turbo I think I would need matching injectors to avoid running out of fuel and with new injectors I need a chip to make them work.
With a new and bigger turbo I think I need a torque converter to make the best use of the turbo.
I guess the problem I have is that I am expecting this new parts to work and in expecting them to work the next issue could be the cam, lifters and valve springs. So in looking ahead and expecting the new items to work I am trying to get a jump on the next possible week link.
I am told a cam is not necessary so I no longer have interest in replacing the cam but I am still looking into replacing the Valve Springs
