What are the test pressures in the Power Source book?Donnie I have a set of MA heads here, my guy said they flow 255 intake and 185 exhaust seems right to me. However every flow bench is different, I think this is the issue, and you guy's is showing too low for all his tests. How come stage 2 heads according to the power source book flow 340 cfm unported for iron s2 heads?
The copy I have in front of me, titled "How to Hotrod your Buick V6", which is basically the same as the Power Source book (I have both) is showing that they are checking the flow of the heads using 40" water.What are the test pressures in the Power Source book?
To convert from 25" water to 28" water, multiply the cfm by 1.06. I only know this because my porter made that note on the flow sheet for the heads for me. I don't know what the conversion is for 40 to 28.OK Donnie whats the conversion factor from 40" to 28". The MA heads I have have extensive porting, so I do believe those numbers.
So, using this conversion chart, what does that do to your 40" water numbers?OK Donnie whats the conversion factor from 40" to 28". The MA heads I have have extensive porting, so I do believe those numbers.
Here I found a chart to do the conversion.
http://www.centuryperformance.com/airflow-conversion-chart-spg-135.html
The modified Stage II intake port in the Power Source book shows 364 cfm @ .600" valve lift at 40" water. Convert that to 28" water and you get 305 cfm @ .600" valve lift.
The Chapman head that was flowed for me came in at 312 cfm @ .600" valve lift at 28" water.
That doesn't seem too far out of the realm of reality to me.
The Stage 1 headers are 304. They've held up extremely well. The plan is to stick with the 304 material.Donnie, what header material are you going to use to? 321 or 304 ? I need a source for bends ...
