SignUp Now!I don't know where I'd find a graph like that.
I agree, Allan. Geometry is very important in keeping rocker tip to valve tip side scrubbing to a minimum. As lift, rpm, spring pressure and cylinder pressure is stepped up, the geometry becomes critical to valvetrain durability.I would think that the spring pressure would not influence guide wear that much if the geometry was correct. Clearance, oil lube availability as well as material selection of both valve and guide would be some of the variables to consider. Valve seat wear would be more interesting.
Allan G.
If I were to shim the rocker shaft up, it would move the rocker tip more towards the middle of the valve at zero lift, but would also move the roller out from center at all other lift positions. Keeping it more in the middle from mid-lift on is more important than getting it centered at zero lift.I think you need to shim the rocker shaft up some. If you color the top the valve and spin it over what kind of mark does it leave on top of the valve?
As long as I have the right rocker to retainer clearance, it will work. I'll be setting the retainer .050" lower than how the street spring was set up with this same rocker assm. and there was plenty of clearance with that configuration. I'm sure I'll be fine with this new configuration.From the pic you put it looks like rockers are setting to low . But what do I know. You will get it sooner or later . Good luck!
I don't have an exact number, but I'd guess it's between .080-.090" from zero lift to full lift.How wide of mark does it leave on top of the valve ?
I don't trust those tools. To me, setting up the rocker geometry is like setting up a rearend gearset. You can use all the fancy tools in the world to setup the gearset, but the final test will always be checking the gear mesh pattern.Don. If those rockers have a stand height tool just use it. It's more accurate than the test your doing. The simple tool will tell you if it's dead on or not.
