Time to go Stage II!
That is some fabulous workmanship your doing there Donnie. Looks so clean and professional. Thanks for the eye candy, can't wait to see it done. If you could keep this under the hood that would be a jaw dropper all in itself. What are you going to do for headers? Any plans on mounting that turbo in the grill area like some of the TSO cars?
Thanks, ttypewhite.
The headers are going to be a shorter tube, larger ID version of my Stage I setup.
The turbo is going to be mounted in the same orientation as the Stage I setup.
I finished installing all the nitrous nozzles, and started drilling the injector bosses out. All the primary injector bosses are finished.
Thanks, Bent6.
I acquired a new milling bit to round the sharp, square corners of the flange on the runners that will bolt to the plenum. I think it will look better with rounded corners. The corners are so sharp now that I have to be very careful when I wrap the engine with the engine bag.
Feel like building a custom draw through intake for a record run Donnie.:D Well, I know the answer, but I still love the work you do when you get started on something.;)
A view down the throat of the runner. Final widening of the runner, and port matching still to be done.
For those interested in putting in their 2 cents, I'm working on the plenum. The goal is to create a plenum volume that will be 250-300 percent of engine displacement. If you're interested, take this picture and sketch out a plenum shape, then repost it for us to check out.
Give me the dementions (sp) ect Donnie and I might be able to do it in mechanical desktop for you.:D Been a while but I've still got the full program if it helps.;)
Have not been in this thread in a while. All I can say is WOW! Can't wait to see the finished product.
Rick
