They all use 60-1 compressor wheels or copies of the 60-1 and are maxed out around 63lbs/min. The stage 3 turbine is good to somewhere around 55-57lbs/min. A mismatch of wheels. However it takes a lot to get near those mass flow numbers. Bolt on stock short blocks will fall short.
Are you sure you are going to be satisfied w/the 11.5's? If so w/the alchy youwill be able to run 28#s w/no problem. I ran the 28#s w/the 86. @30#s there seemed to be no increase. If you are in doubt go the extra and it won't cost you twice. Bison may even have something for you?
No amount of evidence will ever persuade an idiot.
Why bother with a TA49 if you were only going to run it at 17-8 lbs? TE 60 will be no better performance unless you raise the boost significantly. The only thing you will gaining is a healthy turbo.
