- Jul 7, 2007
Yes...true in a general sense but we aren't talking about massive differences...and spring breakage in our application is a rare event so wouldn't worry about that.
The force exerted by the springs when compressed to 1.25" was:
979: 174-184 lbs with standard deviation of 2.40 lb (16 pcs)...throw out the single 174 spring and the range was 179-184 w/std dev of 1.71
980: 193-199 with st dev of 1.56 (16 pcs)...throw out the single 193 and range was 195-199 w/ std dev of 1.2
LT1: 240-253 (12 pcs) w/std dev of 3.77
Original Stock: 170-180 (12 pcs) w/std dev 3.12
Standard deviation is a measure of variation within a group of parts...the bigger the number the larger the variation...so the smaller the number the better. It is a key indicator of a manufacturers ability to produce the same part over and over.
Interesting to see that the 35k mile stock springs had a lower std dev than the brand new "LT1s" which were obviously a low quality spring and very doubtful a genuine GM spring.
By the time I threw out 4 of the 980 springs I installed 12 that had a range of 196-199 w/std dev of 1.19.
I noticed this all took place in Aug-Sep of 2000.
Bob
Outstanding info....thanks very much for everyone's input!
