Been trying to track down this code for a bit and I'm stumped. Things I tried:
So maybe the TCC is bad but wouldn't unplugging it allow the WG to work properly??
I've read that the brake switch can cause these types of issues, but the Cruise Control disengages fine when the brakes are applied.
Are there any other tests I can try to rule out the Brake Switch?? The car does have a Vacuum Brake Conversion so maybe the installer messed something up.
Here are some photos of the electrical connections on the Driver's Side:
Also a photo of the Fuse Panel
Thanks folks.
- Checked all fuses
- Tested TCC (from this post)
- Unplugged TCC
- Tested WG electrical
- 1985 T-Type
- Vacuum hoses are new
- Wastegate solenoid venting to atmosphere (T removed from PCV)
- Vacuum Brakes (previous owner)
![27141583906_0298a88583_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F8%2F7531%2F27141583906_0298a88583_z.jpg&hash=5e57a99cc49b97676378c3f0df04c3a3)
![27140667376_64511b1553_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F8%2F7280%2F27140667376_64511b1553_z.jpg&hash=79dcd403c4bdb45ee067b6c4d498f37e)
![27140686756_4e881c8d51_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F8%2F7028%2F27140686756_4e881c8d51_z.jpg&hash=aebe2aa39fc9a5f8b187856a91f82e05)
Thanks folks.
