stock 109 block .030 over JE's, sad crank, all ARP bolts/studs ect ect
3 Steel Mains
Weber Racing heads
Weber Racing Intake
Weber Racing 206-206 High lift roller Kit
Accufab Plenum/w- 70mm TB
72lb inj
PTE front mount
te45A
Mod front cover
ATR headers
ATR DP
PitBull Dual exhaust
Razor Alky Kit
Turbo tweak chips
Fully Built 200r4 with billet internals
3600 stall 9x11 L/U
Full H&R rear suspension
Hotchkis Lowering springs
Adj shocks
H&R body mounts, engine mounts, trans mount
Kirban Frame/Body brace kit
F body front sway bar w/ poly links, frame bushings
Stock rear 3.42's all fresh clutches T/A cover
Centerline Telstars 15x7 15x8
Vacume Conv.
Cross drilles rotors/ Alum Drums, S10 cyl
Im sure I missed alot more too. Car has updated a/c and blowes cold too. Car should make around 600 w/good tune with pump gas and alky. So I am hoping for some mid 10's until I get booted for no BAR.
