Kendall1214
- Sep 30, 2014
ok guys so I've got a new TA block I'm wanting to go 4inch bore have a stroker crank and wanting to be last cam I get. Right now I have springs enough to go 625 lift. Currently just have ported gn-1 heads. have 1.6 ratio roller rockers. Am planning on going e85 and 9.5:1 compression ratio will get bigger turbo headers and all that down the road. So my question would be can anyone give me a good set of cam specs. Wanting to make 1000hp flywheel! But Just want the cam to get there for now then I'll make my way there while it's running. Speaking of that I don't know how hard it'd be to build the rear end to hold it. Has anyone tried axle tube supports like the pulling trucks use? Or how hard is a Dana 60 swap.?
