- Jan 18, 2011
27"width, 6.25"high , 3"depthCore dimensions ?
AG.
51 rows, 2" in/out and 2.5" pipes
SignUp Now!27"width, 6.25"high , 3"depthCore dimensions ?
AG.
If you know of anyone with any data please share it. As with just about everything Chinese it's a cheap copy of something that at one time probably worked well. We know the cfm flow of a 2" round pipe and it's not enough for what we would be doing. Chances are the core flows more than the outlet pipe. This is typical with cheap Chinese product. No thought or r&d at all. Just a copy of something that is marketed to grab a few $$$ from dumb people.There's some Ebay china vertical ones but the inlet/outlets are only 2".
This core with a better designed tanks and outlet diameter would work extremely well in a alcohol application. E85, methanol, meth injection27"width, 6.25"high , 3"depth
Im pretty sure atr used a spearco core back then, worked real good on my old set up with a 60-1 and alky, only down fall was the 2"in/out and the heavy/noisy/small steel pipes .This core with a better designed tanks and outlet diameter would work extremely well in a alcohol application. E85, methanol, meth injection
actually 2.25 in/outIm pretty sure atr used a spearco core back then, worked real good on my old set up with a 60-1 and alky, only down fall was the 2"in/out and the heavy/noisy/small steel pipes .
Thanks for the info,
Here is some food for thought. Looking at core flow data on an equivalent available core, that size would flow in about 1500 CFM. Now we tend to fall in the "Bigger is better" hole so all of us using the a popular large 27x17x3 core would flow a estimated 650 CFM. I'm sure the horizontal flow may drop more temp but I'm willing the bet the a vertical flow and lower pressure drop would pick up power and even at the expense of some effiecincy.
Now for application specific, If I was running an E85 car, or injecting large amounts of alky I would lean heavily towards the vertical flow. I'm convinced we could build a larger vertical flow since there is a lot of flow margin to gain back some efficiency. I believe this would yield a more perfect intercooler for our cars.
AG.
Air to water cores are great for reducing pressure drop but require plumbing and another heat exchanger for the water. Therefore are nowhere near as practical as air/air. If I had a quarter mile only car that ran on gasoline id absolutely use an air to water Intercooler.Seems like this thread is focused more on air to air, im surprised since id imagine A2W seems to be the best option for pressure drop and performance
I was reading up on A2W, and apparently its not that bad for the street, i mean thats what is used on the bugatti Veyron.Air to water cores are great for reducing pressure drop but require plumbing and another heat exchanger for the water. Therefore are nowhere near as practical as air/air. If I had a quarter mile only car that ran on gasoline id absolutely use an air to water Intercooler.
At a certain power density or if the rules allowed in a restrictive race class it would be worth going to air/water. One good reason to do it would be to clear the front of the car and eliminate the radiator. Looks like over 200hp/hole for a g body racer. It would be difficult to do anything even remotely cost effective for a car capable of being driven thousands of miles on the street that will outperform a properly engineered air to air.All of the Shelby supercharged Mustangs, ZR1 Corvettes, ZL1 Camaros and many of the forced induction Mercedes Benz cars are A2W from the factory. I love the 417MS system for the LSx engines. The 417MS set up has gone low 8's on street cars.
