My "experienced" guess would be heat is the major factor in the coil pack, actually the module, failure.
Since we have experienced these failures from the 90's with our intense summer heat is why I make that statement. GN's from other parts of the country do not have the same failure rate as we have seen.
I have replaced many modules, one this weekend when it was 108 deg, that are fine until the weather is hot and the engine breaks down about 4000 RPM. When I did a long road test in the cooler AM hours, it was fine.
On a GN that was a driver 20 years ago, I experienced my first failure when it would mis-fire when hot, not just warm.
The first thing I did was the "old school" trick of removing the rubber seal from the cowl at the base of the windshield so engine heat would not be trapped especially around the coil pack. That worked for that module except on HOT days in excess of 100 degrees so it was eventually replaced.
A simple test on a hot day is to put your hand at the base of the windshield with the engine hot and running. Remove the rubber strip and feel how much heat is now flowing out from under the hood.
If you want your module to last longer, remove the rubber strip.
