DougsfastZ
4.1
- Jan 30, 2004
I lost a factory head gasket the other night and pulled the motor. I'm going to pull the oil pan and clean any gasket material out of it and the oil pump pickup. I was going to pull a few bearing and check them out.
It's a stock bottom end that is in real good shape. The piston tops are clean, no ridge on the cylinder walls, and still have plenty of cross hatch. I plan on at least installing a set of heads and studding the motor.
What do you all recommend I do while I have the oil pan off?
