I Have a 87 g/n and this winter I had a very experinced guy remove and rebuild my motor. I would like to hav peoples opinion on the build and what to expect from the car.. 1/4 mile? spool, whatever anyone can think of..
short block .20 over
forged pistons
polished crank, billet main caps blueprinted/balanced and milled
roller cam 218/212
water pump
ported front timmong cover
champion gn1 ported iron heads/beehive springs for rolr cam
harland sharp rollr rockers
champion ported intake manifold
throttle body 65mm and plenum
siemen flow matched 55lb injectors
t/a performance stainless steel headers
160 thermostat
200 amp alternator
ac delco coil pack
ac delco ignition module
heat O2 sensor
quad air modified computer for low impedance injectors
quad air chip 55#93 chip for alky
ATR 3.5 downpipe and test
turbo TA66 with custom 3.5" inlet bell and actuator
precision stretch intercooler
quad air fuel pump
aluminum alradco radiator
pete tomka air intake
razor alky kit
pro torque 9.5 conveter 2800-3200 stall
hayden tran cooler
aluminum shal trans pan w/ botm feed filter
full rebuild of the tranny
I might hav missed some stuff just way too much to write.. everything was bought brand new... also stock wheels with M/T Drag radails 235/60/15
I would love to know what the guys with a lot of experince think? good or bad.. how much power?.......thanks
forged pistons
roller cam 218/212
water pump
160 thermostat
200 amp alternator
ac delco coil pack
heat O2 sensor
quad air fuel pump
razor alky kit
hayden tran cooler
