turbonut85
Rarely used member
- Apr 11, 2008
So I'm having a 4.1 build done currently. The machinist has done several TR motors thus far....Here is the call I got today:
I am being told in order to balance the rotating assy...he would need to remove upwards of 260g from each end of my crank...
Is this right?? or even possible?? That's WAY too much to remove IMO. What would cause it to be that far out? He spun 3 separate flex plates and 3 separate balancers...all results were within 6-8g of each other, and the balance machine said to remove near the same amount. Would i be better off doing an internal balance and going with a zero balance flex plate and balancer??
Components are these:
Stock turbo crank 10/10
.040 hyper pistons
stock resized 2 dot rods
Stock balancer
stock flex plate
Any input is greatly appreciated!!
.040 hyper pistons
Stock balancer
stock flex plate
