Where is rear fuel pump harness connector located?
224trimethylpentane
So I decided to dig one of my TTAs out of the graveyard last weekend and clean her up and see if she'd start, but the fuel pump appears to be dead. Either that or mice have chewed through the wires. FP relay works, but I don't hear the pump run. There's always a FP connector back near the bumper somewhere on all cars but I can't seem to find it and it's been too long since I've worked on a TTA to recall. Can someone point out where that connector is? Thanks a bunch!
The connector is in the center right above the rear end.
Thank you. Not too bad for a 30,000 mile car. Just did a lot of cleaning underneath when i changed the fuel pump and installed the hot wire kit. That's why the plug looks so wide,it has the hot wire plug tied to it.
Good luck with your car. Hope it's not your fuel pump,the tank is a pain in the A#% to drop.
I wouldn't have guessed you had 30K miles from that picture. Yeah, I've dropped the tank on one before, can't exactly recall why anymore it's been 20 years ago, must have been a fuel pump issue, or maybe the tank was leaking. I'm thinking the FP should be good as it ran when I parked it, and just sitting around shouldn't cause it to go bad. It's probably mice have chewed up the wires.
