I just ordered a Precision 66 mm from ebay for 459 shipped for a friend of mine. It comes with 3 different springs and all the hardware. The bigger the waste gate, the lower the boost settings you can run. Also the placement of the waste gate is very important too. We had a 46mm waste gate on 3 bolt billet 64/66 turbo. The down pipe was a 3.5" with a 46mm external gate using the 3 bolt stock style puck hole of the turbine housing with a 6 psi spring in it. Well the boost was at 6 psi for few seconds then by the time the car hit 5 grand, the boost creeped up to 27 psi. We move the waste gate to the collector of the passenger side header, off from the turbine housing. we also went to the Precision 66mm gate. Pin point boost control at 6 psi at any rpm.
HTH
Prasad
