- Nov 24, 2001
ive got a problem with fitment with the upgraded club rockers from GSCA, stock iron heads, and the RJC rocker supports!
the middle hole seems to be drilled in the incorrect spot-
almost 1/4 of an inch-
with only the outer 2 bolts and supports inplace, the rockers DO NOT RUB against the RJC supports--
once i install the middle bolt with the RJC support 3 out of 6 rockers rub the RJC supports and hang up-
NOT COOL BY ME and this is on both heads~
once i change it back to the stock rockers all 3 of the RJC rocker supports work great, and there is no binding--
NO PUSHRODS HAVE BEEN INSTALLED
i cannot get the rockers to line up with "THE CLUB" upgraded rocker shafts???????????????
im sure someone else has come across this and realized the shafts are made wrong------
possibly mine were made for champion aluminum heads?
G..D... i know im correct cause ive looked this thing over 10 times
