SignUp Now!Check Johns Performance I have his Braided drain line NiceOriginally posted by BJM
Mine is okay but I think its worth changing while I am getting rid of all my oil leaks. I checked Kirban's site and couldn't find it. He has the feed line though.
TIA
Originally posted by Crazi
....... I will have it next Wednesday so if you want me to report on the look and feel I can.
Assuming you do not have a PT70 or larger....the bigger turbos use larger bolts/studs. You wanna talk PITA?Threads for the return line are: 8mm X 1.25...The flange on the return line is pretty beafy so I would pick up a few different lengths studs, and use the ones that fit best.
