GBGN1
BP Performance Transmissions LLC
- May 26, 2001
Ok, I see the accessory bracket. That is a nice setup. I really like the intake.
Just look in the first page of this thread if you want/ need more pics of intake/ accessories.
SignUp Now!Ok, I see the accessory bracket. That is a nice setup. I really like the intake.
Thanks, I went back and checked them out and I clearly see the GN accessory bracket mounted.Just look in the first page of this thread if you want/ need more pics of intake/ accessories.
They look good but I cannt see me making another set of headers. The zzp's that are on my headers are working great. Make a run of them if there cheap enough . Eventually they will sell.
I agree, nothing is holding me back on mine. This whole build though any custom part short of the castings is virtually modeled to make duplicates easier since a local friend would like to do the same on his.
,Dan
We just found the limit of the speedway motors adapter plate. Was fine at 460rwhp and two 10.80 drag runs.then we fitted ported heads lunched the plate fitted a brand-new one thinking it was just old and soft killed the New plate testing before the drags
Had stretched the plate off the block between all the bolts possibly from converter pressure trying to push both apart
Have you checked w/ Lonnie Diers on his adapters, to if he has one for the 3800's.I talked with the trans adapters guy about his $500 adapter and its power capacity and he gave me some smart ass response about "we build big block adaptors, how in the hell do you think your little V6 would break this". It really turned me off on dealing with the prick so I went this way. If it isn't strong enough I will design my own.
,Dan
