V6RACER said:
On cars with aftermarket engine management I would think it would be an improvement over the stock setup. Cars with a stock ECM setup may not see any gains. Now, how do you find the pros and cons of using different coils and ignition boxes? Are all of them the same or similar in function? I would guess so. It probably comes down to personal preference.
The ecm just tells whatevers on the other end when to fire. It's just generating the same darned *dwell* signal as the distributor would. Once you go to CD, all that unit really looks at is the point open, ie time to fire signal. With a conventional coil, dwell is important since you're trying to *saturate* the coil with just a 12v potential across the ign coil, with CDs it's ~400 volts. Using this 400 volts gives, what's called a faster rise time.
*Spark energy* is generally rated in mj. Mili-joules. An HEI is in the nieghborhood of 20-30 mj, a CD can go from 90-170 mj.. Now with a CD the coil dumps, it's potential electrical energy in just several msecs., while a conventional coil, can maintain it's potential for well over .5 sec.. So what the CD guys try to do, is generate several sparks, to make up for this lack of spark duration.
The critical part in all this thou, is what's happening in the combustion chamber. Once the coil sees the signal to fire, the voltage starts to build, across the spark plugs electrodes. As the voltage builds, there are some atoms torn off the electrodes, and this becomes the ion trail, that the spark follows (just like in the lightning photos were there are all sorts of trace spark events before the lightning strike).
There are as many manufacturing theories about ignitions, as there are cam manufacturers.. It seems all the good entry level ignition text books are now gone, and about the most informative one around nowadays, is Dr Jacobs book How to Optimise Your Ignition System. But, it's tainted since the good Dr is also selling his own brand of ignition systems. If you look up some of the patents quoted on the various ignition bits, you'll see some of the patents have little to nothing to do with the way the unit really works.
While there is some personal preference, there are some items that just don't work, or are troublesome. A quick search here, will show a trail of problems with the DIS4, but some folks have had good luck with them.
If you want to *think*, or *guess*, feel free to, but research and understanding what's going on will always make your car faster, and less prone to breakage.
For the EE's of the group, I'm just trying to put things in lay terms to answer his guestions.
