SignUp Now!norbs said:its up to you but the fastest stock block cars have a distributor.
You are glutton for punishment Louie :biggrin:Louie L. said:Im currently doing the swap in my car.and Mallory CD box.
EightSecV6 said:MY OPINION is The 7al2 along with my MSD crank trigger and MSD distributor makes on paper approximately 1575 flywheel horsepower with only one measly turbo (2570# at 188).Not in theory, but fact. Compare that to ANYONE else's (dist. or dis). When someone else cranks out more power with a DIS, my opinion will change, until that point the distributor makes more power.........for argument sake
Crank reference is "adjusted" in my case for various tuning parameters.
ANY MSD distributor can be adjusted (after removing the mechanical advance) to operate the cam sync independently of the reference pulse.
Sounds a little confusing and complicated to me Bruce but that is not hard to do! :biggrin:
V6 Beast said:Norbs.... You wouldn't be worried about losing a few HP if you could '60.
Check it out. 1.40 :biggrin:
Sully
HighPSI said:FWIW: I now have a distributor conversion kit for the XFI. It is basically an adaptor plug for the module and allows the use of the stock crank sensor. It is plug & play (no splicing) for the electronics. You just have to slide the distributor in where the cam sensor went.
norbs said:I have to go to the distributer to use certain feautures of the gen 7. I.e 2 step and over boost and ignition rev limiting. These features do work right now in the gen 7 on a c3 igntion. However once in a while i will get a violent backfire ,Due to the waste spark, igniting the un burned fuel. I bought a msd billet distributer for $19 so its worth the try.
norbs said:AFter doing some research on the factory crank sensor it appears it uses a 10volt + signal, gnd, and crank signal out into the factory dis module. I only have + ref and - ref for the inputs to the dfi. How do i connect this to the dfi inputs? Do i need a +10v signal still? or do i not need this +10v into the crank signal, do i subsitite it to a 5v signal or a 12v signal? Maybe some experts can chime in, who have done this before
norbs said:However once in a while i will get a violent backfire ,Due to the waste spark, igniting the un burned fuel.
