NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
O2 120-160 at idle
Af 06
L8 40
Int 128
Ats71
Rpm 775-875
Bl142
Tps .42
Iac 02
Cc 20
Thanks for any help!!
SignUp Now!That's what I thought, the car smells like it's running rich/lean I'm not sure but I gotta pull the car half way out of the garage or the fumes will burn your eyes. Tell me what do you think could be causing this?Block learn should be 128 and 02 millivolts should be I think around 750-800
Thanks I'll check it out now I got the day off I wanna figure this outTry checking for a vacuum leak, low fuel pressure or sticking pcv valve. There is a helpful thread from last year on this but I can't seem to post link. Type in high blm turbo Buick and it comes up.
Yup HAHA car right?
IAC could use some adjusting but nothing that should cause a miss. whats the fp set at and does it raise with boost?
Don't worry about blm if its stable, which it appears to be by the int. Right now its just telling you that fuel was added by the ecm, and ecm is in a happy place. Lol. The 142 is very typical of a car with open pcv system.
FP should be set at 43 psi, line off. try that, reset ecm, and see what happens.TT 5.7 chip
Tell me if you can why would it sound and respond great in park at idle but run like crap and stall in gearFP should be set at 43 psi, line off. try that, reset ecm, and see what happens.
