Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Yeah, was thinking PL. lv8
SignUp Now!Fp was low I'm resetting the ECM now how should I set the translator right now it's set for my ls1 maf 0 base and 0 wot it smells like unburned fuel a lil at idleFP should be set at 43 psi, line off. try that, reset ecm, and see what happens.
Mine shows l8On my scan master, Load is l8, not lv
this exactly what the car is doing now to figure out how to stop itGreat question.
Here is my understanding.
The ecm adusted the fuel needs at idle since idle blm is up. There is not a big load at idle (LV) so it will tollerate running lean. Once the engine sees a load it needs more fuel. Since the ecm has not yet self adjusted off idle blm, the lean mixture can cause a stutter and misfire. With the 5.7 chip, the AF will also max at 255 and the ecm does not know ot care how much fuel is needed. The DC is prograamed in the chip based on what TT was told. BUT, it assumes the fp is set to the spec. . . . . . Makes sense?
Edit. buddy beat me to it. Lol
Not a big deal. We are all talking about the same thing . . . Load Variable 8 bit or LV8. With only 2 digits to display the variable on SM and inability to show the V, L8 it is. lolMine shows l8
I just reset the ECM should I let it relearn first or disconnect it nowTry disconnecting translator and start it see what numbers are.
I remember reading rhat the l8 load numbers are just calculated estimates from sensors and aren't really useful for diagnosing or tuning.Also what should l8 be when in gear foot on break or cruising???
