Just placed the order today!!
SPEC CARD
PART #: 67-000-0 ENGINE: BUICK V6 231 ODD FIRE
GRINDING INSTRUCTIONS 1
"" "" 2
"" "" 3
GRIND #: BV6 4718B/ 4718B R120
SPC INST 1:
SPC INST 2:
J. DIAM: 1.948 INT EXH
VALVE ADJUSTMENT .024 .024
GROSS VALVE LIFT .925 .925
DURATION @ .020
TAPPET LIFT 342 342
VALVE TIMING OPEN CLOSE
@ .050 INT 34 90
EXH 94 30
SPECS FOR CAM INST. @ 118.0 CENTERLINE
INT EXH
DURATION @ .050 304.00 304.00
LOBE LIFT .500 .500
LOBE SEPARATION 120.0 FIRING ORDER STD
ROCKER ARM RATIO 1.85 1.85 REQ SHIP DATE
SPEC CARD
"" "" 2
"" "" 3
SPC INST 1:
SPC INST 2:
DURATION @ .020
TAPPET LIFT 342 342
@ .050 INT 34 90
EXH 94 30
INT EXH
LOBE LIFT .500 .500
