2 BRF trans and converter packages
brian
Senior Member
2 complete 10 second capable BRF trannies. Billet drum, rollerized gear train, front pump. These are non lock up units . WOT upshifts will be 5300 rpm.
Both have 550 and 400 boost valves, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout.
shifts are mild/medium at part throttle, quick and firm at WOT. (not harsh)
There are 3 converters available to go with the deal. All are used and in excellent condition with low miles. One is a 3400-3500 stall Art Carr 9in, the other is a 3200-3400 "O" stall AC 9in. For someone looking for less stall, I have a 2800-3000 as well.
1 year warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
This trans features:
Billet forward drum
Billet anchor pin
Aluminum direct clutch apply ring
Transbrake
Alto wide band
7 directs
5 forwards > clutch packs
3 clutch OD
Rollerized pump, low roller, drum, center support
upgraded TCC switch
new pressure switches
higher pressure spring
rev kit
550 and 400 boosters
hardened stator support
resurfaced pump
all new bushings and bearings
AND MORE.
Price with converters and shipping is $2200.
A trans brake can be added to either unit for $100.
1 year warranty.
Billet forward drum
Billet anchor pin
Transbrake
Alto wide band
7 directs
3 clutch OD
upgraded TCC switch
rev kit
resurfaced pump
AND MORE.
You might want to correct this Brian.:smile: Look for the red highlighted wording.
Pro Torque Converter 3200
9 1/2 Pro Torque Converter 3200 Stall part number16921 $350.00 obo 2000 Miles. went 10.74 128 mph VGC.
brf
bump for a killer deal..
makes me want to pull out the 400 and 9" art car..lol :biggrin::biggrin:
how much for the 3000 stall lockup converter if willing to sell?
How much for just a trans with no converter set for up for lockup. Thanks.
