I have that style in 20"...mine are Boss 338s, see pic below. BTW, the general consensus here is 20" is stupid, ghetto, too big, ridiculous, and other things derogatory. Obv you can tell I give a rats a$$ about what anyone thinks about my car but me.
btw, KDWs are awesome.
Ok so what do you guys think???
20" Foose Nitrious wheels wrapped in
BFGoodRich G-Force T/A™ KDW's
The wheels look great....but the chrome will not last ...poor quality chroming ....we used these wheel on a Mustang project I work on,thats why I know.
I should not have any rubbing or clearance issues with these wheels should I be concerned?
These wheels are for show only. I have a set for the track... But this car does not see the track much... It is a Garage queen... Maybe a car show or 2...
Just turned 25,000 original miles...
Im also gonna upgrade the front and rear brakes since they will be so visible..
You should be fine, is it lowered, if so how? I did spindles which screwed up having normal wheels fit. (I am lowered a lot so the GNX flares were necessity to steer...I was rubbing inside and out) Rear are 10" and fit easy...except if you are real low and rear disc the caliper may hit the frame like mine...I had to frame notch like a mini truck to get clearance.
what did you do about brakes up front and in the rear? sounds like u converted to disk in back??? thats what i want to do...
Looking for best and cheapest way to accomplish that...
I want red calipers with drilled and slotted rotors..
I have s-10 blazer rears, they work a little better but are tiny. I want larger diam rotors and higher quality calipers, but thats money I cant spend now.
If you go rear disc after you get the wheels, try to get some that dont change wheel offset or you'll be screwed. Maybe get brakes then wheels.
BTW, 20" on a car that isnt lowered may give a 4x4 look. You will likely run what...285/30 rear and a 245/35 front? That'll give you a wheel well gap that is larger than the side wall height and will make it look raised. (a ratio that you eye sees more gap than tire)Make sense? Mine doesnt look lowered 3"-4" but it is once you see it next to one on 20"s that isnt lowered. I think that is most ppls gripe/stigma here is 20" look GIANT when not lowered.... that and they aren't convo pros.
what is covo pros??
to lower i can just get new springs correct?? i did that to my 2003 expedition put a 3" drop springs all the way around..
Maybe i will leave rear drums now and just add nice red calipers up front and drilled and slotted rotors..
If your going with 20's, please lower the car! Greg did one heck of a good job on his and it looks great! But I will have to say I'm not a fan of them on our cars on stock suspension at all.
But then again, I really dont like any of our cars on stock suspension!!!:biggrin:
I promise i will lower the GN jdpolzin!!!!
but it might be after the brake upgrades!!!
Greg - Convo Pros? Red-neck drag wheels from the 80's? Isn't the GN also from the 80's? At least they don't make it look like a pimp mobile. Why don't you put hydraulics and purple neon under it too and then you can really hang with the low rider crowd or the 'hood'.
